[Qgis-user] Cannot add any GRD data
Roy Marsh roymarsh11 at gmail.com
Mon Sep 19 16:23:34 PDT 2011
OK, I downloaded datafiles with the GRD extension from the DIVA Web site
(no, I have not installed Diva), which itself takes the fies from various
sources. For example, the 'elevation' (that is, altitude) data is as
follows:
  Elevation SRTM30 dataset. CGIAR-SRTM data aggregated to 30 seconds CGIAR
SRTM <http://srtm.csi.cgiar.org/> (3 seconds resolution) Grid 30 seconds
Now, QSIG recognises various types of data with the GRD extension, but none
of them are actually accepted.
I have no trouble with the Alaska data provided with 1.7 but that is img
format
Roy
2011/9/19 Goyo <goyodiaz at gmail.com>
> 2011/9/19, Ramon AndiƱach <custard at westnet.com.au>:
> > So just incase I misunderstand, the answer is really as simple as "use
> open
> > raster, not open vector."
> > Correct?
> The OP has issues opening GRD rasters, not vector layers.
>  _______________________________________________
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110920/58b33648/attachment.html>
