[Qgis-user] Vector2raster
Alexander Bruy alexander.bruy at gmail.com
Wed Sep 21 11:58:05 PDT 2011
you can create new column in your shapefile and populate it with data
using Field Calculator (it support sting to int or real conversion). Then
use GdalTools.
2011/9/21 QGIS Brasil Comunidade brasileira <qgisbrasil at gmail.com>:
> Hi list,
> I did try to use the Vector2raster tool in the raster menu. In this dialog I
> saw that only Real types of attributes can be transformed from vector to
> raster.
> I have a SHP layer and a attribute field as String type.
> How I do to convert a vector file to raster in this case?
> There are someplace where is possible to change the type of attribute from
> String to Real? In this direction I have proceeded in the DBF file the
> change of values from text to numbers.
> Tks in advance...
> Arthur Nanni
> Comunidade QGISBrasil
> www.qgisbrasil.org
> comunidade at qgisbrasil.org
> Qgis-user mailing list
Alexander Bruy
