[Qgis-user] FILTER/selection on WMS request
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Sep 23 13:16:38 PDT 2011
Hi Mayeul
> I use qgis-server 1.7.0 compiled from source (dated 2011-09-16).
Are you using the 1_7_0 branch or the latest dev version? The selection and
filtering with QGIS server are only contained in the developer version.
>&SELECTION=AOIs_Summer2011:36
This syntax looks good to me.
>&FILTER=AOIs_Summer2011:"ACTIVE"='y'
Here it probably needs additional spaces around '='
(...&FILTER=AOIs_Summer2011:"ACTIVE" = 'y'). With the additional spaces, it is
easier for the server to check the sql-injection safety of the string.
Regards,
Marco
Am Freitag, 23. September 2011, 19.57:01 schrieb mayeul.kauffmann at free.fr:
> Hi,
> I cannot get the FILTER or SELECTION parameter to work. I always get all
> features. I want to show (in my general map) where the other (smaller)
> maps are. I read this:
> http://www.qgis.org/wiki/QGIS_Server_Tutorial#FILTER_parameter
> I use this kind of request:
> http://localhost/cgi-bin/qgis_mapserv.fcgi?MAP=/home/kauffml/Kimberley/QGIS
> /Marange_2011-09-23_mk_tmp_2011-09-23_19h31m07s_200.qgs&SERVICE=WMS&VERSION
> =1.3.0&REQUEST=GetPrint&CRS=EPSG:32736&FORMAT=png&DPI=96&map0:EXTENT=442303
> ,7826493,443122,7827312&map0:LAYERS=15_SEPTEMBER_2010&map1:EXTENT=442303,78
> 26493,443122,7827312&map1:LAYERS=features_colored&map2:EXTENT=442303,782649
> 3,443122,7827312&map2:LAYERS=Spring2011&map3:EXTENT=442303,7826493,443122,7
> 827312&map4:LAYERS=AOIs_Summer2011,2011JulyAugust&map4:EXTENT=419701,781270
> 1,447025,7841669&map3:LAYERS=2011JulyAugust&LAYERS=15_SEPTEMBER_2010,Spring
> 2011,2011JulyAugust,AOIs_Summer2011,features_colored&template=composer1&SEL
> or
> /Marange_2011-09-23_mk_tmp_2011-09-23_19h31m07s_800.qgs&SERVICE=WMS&VERSION
> =1.3.0&REQUEST=GetPrint&CRS=EPSG:32736&FORMAT=png&DPI=96&map0:EXTENT=443130
> ,7832515,446813,7836198&map0:LAYERS=15_SEPTEMBER_2010&map1:EXTENT=443130,78
> 32515,446813,7836198&map1:LAYERS=features_colored&map2:EXTENT=443130,783251
> 5,446813,7836198&map2:LAYERS=Spring2011&map3:EXTENT=443130,7832515,446813,7
> 836198&map4:LAYERS=AOIs_Summer2011,2011JulyAugust&map4:EXTENT=419701,781270
> 2011,2011JulyAugust,AOIs_Summer2011,features_colored&template=composer1&FIL
> Thanks for any help!
> Mayeul
> Qgis-user mailing list
