[Qgis-user] displaying coordinates as DMS
Andreas Neumann a.neumann at carto.net
Sun Sep 25 23:37:49 PDT 2011
 There is also the "Coordinate Capture" Plugin that allows you to read
 out values in any coordinate system, regardless of what you use in your
 project.
 Turning on "on-the-fly" projection and setting a different projection
 has the disadvantage that it is reprojecting your data, which takes more
 time and changes the display of your map projection.
 So I would propose to use the "Coordinate Capture" plugin, which is
 also described in the QGIS manual (QGIS core plugins).
 Not sure if it is available in QGIS 1.4. 1.4 is rather old and I would
 propose that you update. There is a wealth of new features and bug
 fixes.
 Andreas
 On Sun, 25 Sep 2011 20:06:40 -0700, John Comeau wrote:
> I'm using qgis 1.4.0-enceladus on Debian GNU/Linux, and although the
> release notes specifically state that the coordinates in the status
> bar can be displayed in DMS format (degrees-minutes-seconds) rather
> than the decimal degrees format, I cannot find anywhere online, nor
> within the application, how to accomplish this. Please forgive me if
> the answer is already in the archives, I've searched to the best of
> my
> ability to no avail. Thank you -- jc
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
