[Qgis-user] More problems with 1.7.1
Agustin Lobo alobolistas at gmail.com
Mon Sep 26 01:06:59 PDT 2011
Not obvious at all: according to Synaptic the same upgrade installed
python-qgis 1.7.1.~lucid1
python-qgis-common 1.7.1.~lucid1
etc
all qgis entries are 1.7.1.~lucid1 and from the same repository
Agus
2011/9/26 Noli Sicad <nsicad at gmail.com>:
> Try to install the right /compatible qgis-python that goes with 1.7.1.
> Obviously, right qgis-python package in not installed or incompatible version.
> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
> The 2 and 3 are all related to qgis-python,
> Noli
> On 9/26/11, Agustin Lobo <alobolistas at gmail.com> wrote:
>> 1. After starting up, select Options and crash. Console message:
>> alobo at delia:~$ qgis
>> Warning: loading of qgis translation failed
>> [/usr/share/qgis/i18n//qgis_en_US]
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> Warning: Couldn't load Python support library: Cannot load library
>> file: No such file or directory)
>> Fatal: ASSERT: "myResult == 0" in file
>> /build/buildd/qgis-1.7.1/src/app/qgsoptions.cpp, line 824
>> Aborted
>> 2. Local plugins not loaded, it seems it does not read the local .ggis
>> directory
>> 3. There is no installation tool for python plugins
>> Tried to go back to 1.7.0 but it's not on ubuntugis-unstable any more
>> and ubuntugis-stable has 1.6 !
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
