[Qgis-user] Problem changing a shapefile's coordinates
S. Koukoulas sotkouk at gmail.com
Tue Sep 27 03:52:02 PDT 2011
for vectors try the ftools plugin (Vector> Data management tools)
(defines projection permanently)
or use <save as...> to save the vector file to a different projection
(make sure that the original is correctly defined).
for rasters use the GDAL tools plugin
cheers,
sotos
On 09/27/2011 12:52 PM, giannis Nj wrote:
> Hello,
> I have a .tiff file and a .shp one, showing the same area in the map
> but they come in different coordinates. From the Properties of these
> files I give them the same projection (4326 - WGS84), same as the
> project properties, but still they don't match. Actually, the
> coordinates of the shapefile remain the same (different from the
> project's), something that I thought would change by changing the CRS.
> I guess it's not that simple to change the coordinates in a file, so i
> would like to ask how it is possible to manage this so that the two
> files will come in the same coordinates. Is something in the settings
> that i forget to do? Is this able in QGIS or i have to try on another
> GIS program?
> Thank you.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110927/fb9617ed/attachment.html>
