[Qgis-user] Problem rotating labels
bernhard.stroebl at jena.de bernhard.stroebl at jena.de
Tue Sep 13 06:38:02 EDT 2011
you basically need a field for x and y coordinates each and use them
for the label position.
see this discussion
http://osgeo-org.1803224.n2.nabble.com/Enhanced-labels-in-1-7-0-td6207317.html
regards
Bernhard
Am 13.09.2011 12:22, schrieb magerlin:
> I am trying to rotate some labels from a simple shape file point layer with a
> text string and an integer angle attribute.
> But when using the ABC button and selecting "Data defined settings" the
> "Rotation", "Vertical alignment" and "Horisontal alignment" selectors are
> infunctional:
> http://osgeo-org.1803224.n2.nabble.com/file/n6786937/Image3.png
> Using the Label "wrench" tool button is no better choise, since every thing
> here is "greyed out":
> http://osgeo-org.1803224.n2.nabble.com/file/n6786937/Image2.png
> Am I doing something wrong?
> I am using Qgis 1.7.0 in Win 7 installed from the stand alone installer.
> Best regards
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-rotating-labels-tp6786937p6786937.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
