[Qgis-user] Re: Mac OS X, Sextante and other plugins or the forgotten users..
Julian Bogdani jbogdani at gmail.com
Sun Apr 1 03:19:35 PDT 2012
Hello,
I'm running QGIS on MacOS also, and having problems with SEXTANTE. I was able to successfully install it from the QGIS Official Repository 2, but SAGA does not work.
Here is the log for a simple points to lines analysis:
ALGORITHM|Sun Apr 01 2012 12:16:46|Sextante.runalg("saga:convertpointstoline(s)","/Users/jbogdani/qgis/points.shp","cat1","cat2",None)
INFO|Sun Apr 01 2012 12:16:46|SAGA execution commands|libshapes_lines "Convert Points to Line(s)" -POINTS /Users/jbogdani/qgis/points.shp -ORDER "cat1" -SEPARATE "cat2" -LINES /Users/jbogdani/sextante/tempdata/1333275406.0329.shp
INFO|Sun Apr 01 2012 12:16:46|SAGA execution console output|/Users/jbogdani/sextante/saga_batch_job.sh: line 1: saga_cmd: command not found
Julian Bogdani
http://bradypus.net
On 1 Apr 2012, at 12:09 , gene wrote:
> I installed this plugin (and before the experimental 0.1 from
> http://code.google.com/p/sextante/source/browse/#svn%2Ftrunk%2Fsoft%2Fbindings%2Fqgis-plugin
> ) otherwise I could not say that it not works with SAGA or R.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-Sextante-and-other-plugins-or-the-forgotten-users-tp4676106p4676150.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120401/50fc5ddb/attachment.html>
