[Qgis-user] Re: Mac OS X, Sextante and other plugins or the forgotten users..
Julian Bogdani jbogdani at gmail.com
Sun Apr 1 03:44:10 PDT 2012
In QGIS:
Plugins > Fetch Python Plugins
Repositories: "Add third party repositories"
Options: select "Show all, even those marked as experimental"
Plugins: filter type sextante
You'll see it in the list (under repository you'll find QGIS Official Repository 2), go ahead and install.
Julian Bogdani
http://bradypus.net
On 1 Apr 2012, at 12:34 , Noli Sicad wrote:
> What is the QGIS Official Repository 2, could give details on this.
> It seems that I am not getting SEXTANTE as well in my Mac OS X QGiS.
> Thanks.
> Noli
> On 4/1/12, Julian Bogdani <jbogdani at gmail.com> wrote:
>> Hello,
>> I'm running QGIS on MacOS also, and having problems with SEXTANTE. I was
>> able to successfully install it from the QGIS Official Repository 2, but
>> SAGA does not work.
>> Here is the log for a simple points to lines analysis:
>> ALGORITHM|Sun Apr 01 2012
>> 12:16:46|Sextante.runalg("saga:convertpointstoline(s)","/Users/jbogdani/qgis/points.shp","cat1","cat2",None)
>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution commands|libshapes_lines
>> "Convert Points to Line(s)" -POINTS /Users/jbogdani/qgis/points.shp -ORDER
>> "cat1" -SEPARATE "cat2" -LINES
>> /Users/jbogdani/sextante/tempdata/1333275406.0329.shp
>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution console
>> output|/Users/jbogdani/sextante/saga_batch_job.sh: line 1: saga_cmd: command
>> not found
>> Julian Bogdani
>> http://bradypus.net
>> On 1 Apr 2012, at 12:09 , gene wrote:
>>> I installed this plugin (and before the experimental 0.1 from
>>> http://code.google.com/p/sextante/source/browse/#svn%2Ftrunk%2Fsoft%2Fbindings%2Fqgis-plugin
>>> ) otherwise I could not say that it not works with SAGA or R.
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-Sextante-and-other-plugins-or-the-forgotten-users-tp4676106p4676150.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120401/e73a37c9/attachment.html>
