[Qgis-user] SEXTANTE for QGIS has been released
Paulo van Breugel p.vanbreugel at gmail.com
Mon Apr 2 05:26:40 PDT 2012
Hi Victor,
A great idea, the original one :-). I am sure you are right the way data
is organized in GRASS is scary for new users. It took me some time
before I got used to GRASS and its way of data organization. And
although I like it very much now, it is a steep learning curve. So this
would really open the GRASS set of functions for a much wider audience.
I am also happy you are planning the other way around for the near
future. Unfortunately I cannot offer much help in terms of programming,
but when the time is there, I am happy to do some testing if needed.
Best regards,
Paulo
On 04/02/2012 12:10 PM, Victor Olaya wrote:
> Paulo,
> The idea (at least, my original idea) was to let users with no GRASS
> knowledge to use GRASS algorithms from a more common GIS interface. So
> they do not have to worry about mapsets and things like that, and they
> execute the algorithm just like they would do with any other one. The
> mapset and location is created automatically each time the algorithm
> is run, and all data imported into it. Then the results are exported
> and loaded in the GIS.
> This might have some limitations, of course, but in the Java version
> of SEXTANTE it has proved very useful to make those algorithms
> available to most users, specially those that were a bit afraid of the
> complexity of GRASS or were not used to its interface or its
> command-line syntax.
> Using GRASS layers is a different thing, but as I said, I hope to have
> that already in a near future, and also to be able to use those GRASS
> layers in other algorithms, so SEXTNATE will become the intermediate
> layer for all analysis and data sources, and doing it as transparently
> as possible
> Regards
> El día 2 de abril de 2012 11:54, Paulo van Breugel
> <p.vanbreugel at gmail.com>  escribió:
>> On 04/02/2012 09:47 AM, Paolo Cavallini wrote:
>> On 30/03/2012 23:19, Victor Olaya wrote:
>> Well, the idea is just the opposite: to use any raster or vector layer
>> in GRASS, directly from QGIS. "Any" in this context means any "normal"
>> Please remember also that it is possible to use rasters in GRASS without
>> importing them, but just registering them (r.external), with insignificant
>> loss of performances. Thus, we can more or less forget about grass rasters
>> in their native format, for most of the uses.
>> All the best.
>> Just to be clear, I assume you mean here that there is no need to convert
>> (import) other raster layers to GRASS layers in order to use GRASS
>> functions? I am asking because this option doesn't help the user who has
>> his/her data in a GRASS database.
>> For me the strict and transparent handling of region settings and projection
>> has always been one of the strong points of GRASS, and I am curious how the
>> workflow will be when working with external rasters. Like with internal
>> rasters, an external raster layer does need to be in the same projection as
>> the current location. Furthermore, raster functions use the region settings
>> (extend, resolution) of the current mapset as far as I understand.
>> When importing, it is possible to create a new location on the fly based on
>> the raster you are importing. This makes it easier to deal with the above (I
>> think), e.g., by creating a temporary location. I am not sure linking an
>> external raster offers the same option (I had a quick look, but can't find
>> the option, but maybe I just overlooked it). But then, the normal import
>> function allows to create a location based on a raster without actually
>> importing the raster. So the two could be combined.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120402/0561f8be/attachment.html>
