Re: [Qgis-user] about some ellipsoïdal distances
G. Allegri giohappy at gmail.com
Fri Apr 6 03:17:10 PDT 2012
Pull request done:  https://github.com/qgis/Quantum-GIS/pull/115
giovanni
2012/4/6 Paolo Cavallini <cavallini at faunalia.it>
> Il 06/04/2012 12:01, G. Allegri ha scritto:
> > Probably I've found the bug.
> > In Qgis the semi-minor axis of the ellipsoid is calculated with:
> > b = a - (f/a)
> > where
> > b = semi-minor axis
> > a = semi-majot axis
> > f = inverse flattening
> > while it should be:
> > b = a - (a/f)
> > In Qgis the WGS84 semi-minor axis is 6378136,xxx
> > while it should be 6356752.xxx
> nice shot, thanks a lot!
> could you please fill up a ticket, or change the code yourself and send a
> pull request?
> all the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120406/7ffc1bc2/attachment.html>
