[Qgis-user] Wrong Area for large polygons in vector/Geometry Tools/Export/Add Geometry Columns
Agustin Lobo alobolistas at gmail.com
Sun Apr 8 07:36:33 PDT 2012
Results for large polygons are wrong when calculated with
Example in
http://dl.dropbox.com/u/3180464/BorneoLCv2google.zip
Check, for example, polygons with ID 25967 and 26570: according to the table,
the areas are
25967: 8550196769
26570: 1736474738
while visual inspection indicates that 26570 is obviously much larger.
Both results are different than those calculated by R:
25967:    9294889613
26570: 205414657947
Discrepancies with R are particularly large for polygons with area > 1E+10
qgis 1.7.4 on ubuntu 10.04 32bits
This might be related to issue
http://hub.qgis.org/issues/4955
Agus
