[Qgis-user] QGis Server on Windows
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Thu Apr 12 02:30:33 PDT 2012
Hi Holger,
        You can run Apache on Windows Server 2008. However a quick search
implies that qgis server and IIS (the built in windows server 2008 web
server) probably won't get along:
http://www.townshipgis.org/project-background/open-web-mapping/qgis-server
"It is not clear yet whether machines running the IIS (Windows) web
servers will one day be able to run QGIS Server."
Though its unclear how old that document is.
Jonathan
To:     "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Date:   12/04/2012 10:27
Subject:        [Qgis-user] QGis Server on Windows
Sent by:        qgis-user-bounces at lists.osgeo.org
Hello,
is it possible to run the qgis-server with a windows server 2008 instead
of apache?
Holger
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120412/4d1c1c1b/attachment.html>
