[Qgis-user] Join problem with QGIS(-server)
Julian Bogdani jbogdani at gmail.com
Fri Apr 13 06:19:08 PDT 2012
Hello,
I use use joins in QGis using different data sources, and I've never had any problem. Working with QGis-server I see that a working join on the desktop does not work on the server.
I've tried with different data sources, such as mysql, dbf, etc. Everything works fine in the desktop version, none of them works on the server.
I thought it was a problem of the web client (http://hub.qgis.org/issues/5324) but it seems it's a QGIS (server) issue,
Any help? Anybody is actually using joins with QGis server?
Julian Bogdani
http://bradypus.net
