[Qgis-user] Announce: new plugin: convert a 1-band raster and its qml file to paletted or RGB raster
benoit-3 at bc-consult.com
Sun Apr 15 05:21:43 PDT 2012
Hello QGIS users,
Messages have been posted on the QGIS mailing-lists about hurdles to
create a colour raster file from 1-band raster and its QGIS colour
palette. In response, I've tried to create an acceptable solution and am
please to announce the bccAddRColor plugin.
This new plugin ("one-band raster to paletted or RGB raster", version
0.1.1) is available from the BC Consulting repository [0].
If you are interested to use/test this plugin, please add the above
repository to QGIS (see [1] on how to add a repository).
Once installed the plugin can be found in the "Raster/Raster Colours"
menu.
The plugin asks for an input 1-band raster file, the QGIS qml file
associated with it and the name of the output raster file. The output
raster file can be either a 1-band paletted raster or a 3-band RGB
raster.
You can read more info, if interested, at [2].
Best regards,
Benoit
[0] http://www.bc-consult.com/free/plugins.xml
[1] http://www.bc-consult.com/free/repinst.htm
[2] http://www.bc-consult.com/free/bccAddRColor.html
