[Qgis-user] best way to change srs definitions
Duarte Carreira
DCarreira at edia.pt
Tue Apr 17 11:06:54 PDT 2012
That's 2 problems when you need to distribute qgis in an organization:
1) you have to configure each machine per profile, not just once per machine (copy the file to every user's .qgis)
2) you have different non-standard srsid's
I am thinking on editing the srs.db in qgis/resources, and distributing qgis via a zip file... users won't be able to update qgis unless I update the zip file and they decompress over the original installation.
What do you think?
-----Mensagem original-----
De: Giovanni Manghi [mailto:giovanni.manghi at faunalia.pt]
Enviada: terça-feira, 17 de Abril de 2012 17:49
Para: Duarte Carreira
Cc: qgis-user at lists.osgeo.org
Assunto: RE: [Qgis-user] best way to change srs definitions
On Tue, 2012-04-17 at 16:40 +0000, Duarte Carreira wrote:
> The problem with the custom crs is that it's saved to the user
> profile,
custom CRSs are stored in .qgis/qgis.db that once is prepared you can copy in different machines. This is not overwritten when upgrading.
> also does it override an existing epsg definition?
no, it creates new ones with ids starting from 100000
cheers
-- Giovanni --
