[Qgis-user] SEXTANTE - a few ideas/issues
johnrobot johnrobot at gmail.com
Fri Apr 20 10:58:26 PDT 2012
Hi
I have just started trying out SEXTANTE in QGIS and I really like the idea.
A huge step forward and it provides some FME-like capabilities. When working
a bit with SEXTANTE, a few ideas/issues have come up:
1
When trying to run v.buffer (and quite a few other tools as well), I get
this error message:
Ett fel har inträffat vid Pythonexekvering:
  File
"C:/Users/Magnus/.qgis/python/plugins\sextante\gui\SextanteToolbox.py", line
104, in executeAlgorithm
    dlg = ParametersDialog(alg)
  File
"C:/Users/Magnus/.qgis/python/plugins\sextante\gui\ParametersDialog.py",
line 35, in __init__
    self.ui.setupUi(self, alg)
  File
line 56, in setupUi
    self.paramTable = ParametersPanel(self.alg, self.dialog)
  File
"C:/Users/Magnus/.qgis/python/plugins\sextante\gui\ParametersPanel.py", line
38, in __init__
    self.initGUI()
  File
65, in initGUI
    widget = self.getWidgetFromParameter(param)
  File
118, in getWidgetFromParameter
    layers = QGisLayers.getVectorLayers(param.shapetype)
  File "C:/Users/Magnus/.qgis/python/plugins\sextante\core\QGisLayers.py",
line 33, in getVectorLayers
    uri = str(layer.source())
UnicodeEncodeError: 'ascii' codec can't encode character u'\xf6' in position
46: ordinal not in range(128)
Python version:
2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)]
QGIS version:
1.7.4-Wroclaw Wroclaw, 411aff6
Python sökväg: ['C:/Users/Magnus/.qgis/python/plugins\\sextante',
'C:\\Users\\Magnus\\.qgis\\python\\plugins\\cswclient',
'C:/PROGRA~2/GIS/QGIS/apps/qgis/./python', 'C:/Users/Magnus/.qgis/python',
'C:/Users/Magnus/.qgis/python/plugins',
'C:/PROGRA~2/GIS/QGIS/apps/qgis/./python/plugins',
'C:\\PROGRA~2\\GIS\\QGIS\\bin\\python27.zip',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\DLLs',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\plat-win',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\lib-tk',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\qgis\\bin',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages\\PIL',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages\\win32',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages\\win32\\lib',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages\\Pythonwin',
'C:\\PROGRA~2\\GIS\\QGIS\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode',
'C:\\Users\\Magnus\\.qgis\\python\\plugins\\fTools\\tools',
'C:\\Users\\Magnus\\.qgis\\python\\plugins\\mmqgis/forms']
2
When hovering with the mouse over a tool in the toolbox, how about showing a
short explanation on what the tool does?
3
When defining folders, such as the Saga folder, how about using a file
window instead of a blank space for entering the path? This seems easier to
me.
4
A lot of windows, such as the ftools – Centroids, seem to use a lot of space
for no reason. I think that they should be as small as possible.
5
Quite a few buttons, such as the About SEXTANTE – Close, seem much to large.
5
The help button, the ”?”, doesn´t seem to provide any additional
information. Is this planned? Otherwise, I think that it should be removed.
6
I see quite a few abbreviations, such as ”src filename”, ”maxdist”,
”hspacing” and ”patval”. To me, this can be confusing in some cases, and I
think that the full text should be provided. Not sure if this is defined in
the tool and outside of SEXTANTE.
7
When trying to add a tool in the modeller and there is a parameter values
missing, the missing values should be highlighted to guide the user.
8
The user should be able to inspect/edit added components in the modeller,
using for example a double click or a right click.
9
I would like to see some undo/redo functionality in the modeller.
10
Modeller: When shifting between ”Design” and ”Python code”, the view in
”Design” is sometimes shifted.
I use QGIS 1.7.4 and SEXTANTE 1.0.4 on Win Vista 64 bit.
Regards,
Magnus
View this message in context: http://osgeo-org.1560.n6.nabble.com/SEXTANTE-a-few-ideas-issues-tp4902812p4902812.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
