[Qgis-user] SEXTANTE - a few ideas/issues
Victor Olaya volayaf at gmail.com
Fri Apr 20 12:48:05 PDT 2012
Tables have a setCellWidget method, which makes that easier.... With
trees i think you have to create you own delegate.... Will try to work
on it, and might ask you for some help :-)
Thanks!
El día 20 de abril de 2012 20:57, Alexander Bruy
<alexander.bruy at gmail.com> escribió:
> Victor,
> 2012/4/20 Victor Olaya <volayaf at gmail.com>:
>>> 3
>>> When defining folders, such as the Saga folder, how about using a file
>>> window instead of a blank space for entering the path? This seems easier to
>>> me.
>> good idea! :-) I do not know if it is easy to put a complex widget
>> into a treecell. Someone has done that with QT before?
> I did something like this but for table cell. If you point me in code
> where this should be I'll try to implement it
> Alexander Bruy
