[Qgis-user] add geometry column error
Piotr Pachół piotrpachol at gmail.com
Mon Apr 23 07:14:35 PDT 2012
Hello,
I have problem with  adding geometry column to some kind of shapefiles.
After executing the function 'export/add geometry column' all xcoord and
ycoord values equals zero.
I attached zipped shp file with 3 points.
Do you have any suggestions ?
I work with Qgis 1.7.4 Wrocław and Windows XP.
Regards,
Piotr
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120423/e3869e82/attachment.obj>
