[Qgis-user] Sextante algorithms from gvSIG CE
Nathan Woodrow madmanwoo at gmail.com
Wed Apr 25 00:54:45 PDT 2012
Cool.  Will have to try this out.
Thanks.
- Nathan
On Wed, Apr 25, 2012 at 5:09 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Nathan, I know that it is a big turn of...and that is why I decided
> not to use the SAGA python bindings (they are too hard to install for
> the average user) Instead, SEXTANTE runs SAGA on the command line, so
> you just have to install SAGA for windows (very very easy), and then
> in the SEXTANTE configuration tell SEXTANTE which is the SAGA folder.
> That should be enough :-)
> Regards
> El día 25 de abril de 2012 09:01, Nathan Woodrow <madmanwoo at gmail.com>
> escribió:
> > Victor,
> > Do you know if the SAGA python bindings are available for Windows?  I
> would
> > really like to test all this out but last time I looked you had
> to compile
> > SAGA python bindings for windows and that is a pretty big turn off for
> > users.
> > - Nathan
> > On Wed, Apr 25, 2012 at 4:48 PM, Victor Olaya <volayaf at gmail.com> wrote:
> >> There is, in fact, a category called "request for algorithms" at
> >> http://hub.qgis.org/projects/sextante/issues
> >> I still have to think about how to create those new algorithms. The
> >> original Java SEXTANTE (the one in gvSIG CE) contained the SAGA
> >> algorithms ported to Java, plus quite a few new ones that I developed
> >> myself. Since now SEXTANTE for QGIS uses SAGA, I am thinking that
> >> maybe it would be good to write those missing algorithms not in QGIS
> >> directly, but in SAGA instead, so I contribute to the project, while
> >> algorithms can still be used from  QGIS.
> >> Anyway, whatever algorithm you are missing, just add it there and we
> >> will for sure work on it. My idea is to have a comprehensive list of
> >> algorihtms available in SEXTANTE for QGIS, much more complete that the
> >> one in SEXTANTE for gvSIG, since now the software is improved and it
> >> is easier to extend it.
> >> As donovan said, this is just the beginning :-)
> >> Regards
> >> El día 25 de abril de 2012 03:14, Donovan Cameron
> >> <sault.don at gmail.com> escribió:
> >> > Sextante toolbox is something that just got introduced to QGIS, so I
> >> > think
> >> > eventually it would.
> >> > I suggest for the meantime you
> >> > visit http://hub.qgis.org/projects/sextante/issues and request any
> tools
> >> > you
> >> > would like to see added.
> >> > Regards,
> >> > Donovan
> >> > On Tue, Apr 24, 2012 at 3:25 PM, Piotr Pachół <piotrpachol at gmail.com>
> >> > wrote:
> >> >> Hello,
> >> >> Are any plans to implement in Sextante plugin of Qgis algorithms
> which
> >> >> are
> >> >> already available in gvSIG CE ?
> >> >> I mean algorithms from such groups: 3D, TIN, Visibility and lighting
> >> >> and
> >> >> many others.
> >> >> Regards,
> >> >> Piotr
> >> >> _______________________________________________
> >> >> Qgis-user mailing list
> >> >> Qgis-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120425/18f87cef/attachment.html>
