[Qgis-user] qgis on linuxmint?
Werner Macho werner.macho at gmail.com
Sat Apr 28 12:54:12 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Agus!
I am using LMDE (Linux Mint Debian Edition) since more than a year now
and I am very satisfied with it.
Before I used Gentoo Linux (which also worked fine) but Gentoo was too
much compiling time for me .. So I decided to switch back to something I
use on servers since a long long time .. Good old debian .. But as plain
debian is on one side rock solid - the other side is .. you always are a
bit outdated .. Thats the reason why I choose the rolling release LMDE
based on debian testing ..
I never had a real problem using it and can recommend it for everything
you want to do..
So on your side - if you want to switch away from ubuntu .. don't take
linuxmint - it is based on ubuntu anyway (ok they try to not use unity -
but the base is still the same).. just take LMDE .. debian, stable, with
newer software from mint..
(I don't want to start a distribution flamewar here - it's just that I
am really satisfied with it)
just my 2ยข
kind regards
Werner
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+cSuEACgkQDAH1YiCxBgmLUwCggFBCejo2SaUYoqHYTSt3BWfo
Y0sAnR2ddgxDDROb8dm9YL2uL8QmNvqn
=2cg3
-----END PGP SIGNATURE-----
