[Qgis-user] Slope not calculating correctly
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Apr 10 09:25:01 EDT 2012
Hi Rudi
 From Version 1.8 on, you can set the parameter 'z-scale' if your x-/y-
units are different than the z-unit.
If e.g. x-/y- is degrees and z meters, you may set z-Factor 111120.
Regards,
Marco
On 10.04.2012 12:20, Rudi Thiede wrote:
> I've got a DEM, basically a cut-out of SRTM data. Trying to calculate
> its slope gives me extremely weird output, such that all values are
> >89 degrees.
> Dataset: http://linfiniti.com/~rudi/SRTM.zip
> <http://linfiniti.com/%7Erudi/SRTM.zip>
> Can anyone confirm? I'm suspecting a local issue though, not the data ...
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120410/e5be3d94/attachment.html
