[Qgis-user] Re: Georeferencer not loading
dartmoor
adzwalters at gmail.com
Wed Apr 25 04:34:51 EDT 2012
Thanks for the suggestion Morten,
Unfortunately when I click on the Georeferencer icon the main QGIS window
remains selected. Clicking on any other plugin automatically launches it
and the plugin window is automatically active. Therefore I know that the
Georeferencer is not loading.
On 25 April 2012 18:27, magerlin [via OSGeo.org] <
ml-node+s1560n4915981h95 at n6.nabble.com> wrote:
> Hi
> I have sometimes experienced the same - nothing seems to happen when I
> select the georeferencer.
> But the fact is that something happens, but the opened Georeferencer
> window is hidden somewhere.
> One case is if I have used two displays and put Qgis on the one and the
> Georeferencer window on the other. If I close Qgis from there and later
> opens Qgis using only one display, then the Georeferencer window will
> sometimes seems to be missing (but it is as a matter of fact shown on a non
> existing second display) - this is a Windows issue and not Qgis.
> The best solution is to start Qgis using two displays and move the
> Georeferenser window to your main screen before closing Qgis down.
> If that is no possible then try using the combination of the ALT+Space
> keys. This opens a small window menu with the possibilities to Move (used
> the arrow keys after this selection), Restore or Maximize windows - I think
> I have sometimes used this as a solution to get it back on my main display.
> Hope this can help...
> Regards Morten
> Qgis 1.7.4 Stand alone installer in Win7 64 bit
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Georeferencer-not-loading-tp4915363p4915981.html
> To unsubscribe from Georeferencer not loading, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4915363&code=YWR6d2FsdGVyc0BnbWFpbC5jb218NDkxNTM2M3wxNDkxMzU1NTM0>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Georeferencer-not-loading-tp4915363p4915997.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120425/8eb1ef86/attachment-0001.html
