[Qgis-user] Problem with Managing Plugins with qgis 1.8
Etienne Tourigny etourigny.dev at gmail.com
Fri Aug 3 07:44:09 PDT 2012
That depends on the particular plugins.  Others should install fine now.
Etienne
On Fri, Aug 3, 2012 at 11:17 AM, Sergio Vignali
<vignalisergio30 at gmail.com> wrote:
> I have installed the plugin,
> I have created manually the folder and I have changed the permission.
> Is it possible that there will be other problems in QGis?
> 2012/8/3 Etienne Tourigny <etourigny.dev at gmail.com>
>> Actually I had that same problem after installing qgis to a new
>> machine. It seems that the python/plugins folder is not created when
>> it is absent. This deserves a bug report.
>> Etienne
>> On Fri, Aug 3, 2012 at 5:52 AM, Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>> > Il 03/08/2012 10:45, Sergio Vignali ha scritto:
>> >> I have the same problem!
>> >> I have just controlled the folder,
>> >> into / home / sergio / .qgis I have only gdal_pam folder and
>> >> python / plugins one doesn't exist.
>> > so there is something wrong with your installation
>> >> Must I create the folders?
>> > no
>> > Paolo Cavallini - Faunalia
>> > www.faunalia.eu
>> > Full contact details at www.faunalia.eu/pc
>> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Sergio Vignali
> CERM Centro Rapaci Minacciati
