[Qgis-user] Vector/Raster Projection Problem
Terry Morse tmorse at teleport.com
Sat Aug 11 02:09:01 PDT 2012
I'm not sure what I've done differently, but I managed tonight to get the projections to overlap.  The counties vector layer appears to have been reprojected to WGS84, and the display projection is NAD 83 (EPSG: 2992).  I tried to duplicate this in a second instantiation of QGIS, so far unsuccessfully.  I'm going to have to experiment more.
In the interim, When I try to clip the raster file in the successful superimposition to the extent of the counties layer using the raster clipper and get the error message: Computed -srcwin falls outside raster size of 28800x19200.  Any idea what that is about?
Thanks,
Terry
>From: richard burcher <drownedfrog at gmail.com>
>Sent: Aug 10, 2012 3:49 PM
>To: qgis-user at lists.osgeo.org
>Subject: Re: [Qgis-user] Vector/Raster Projection Problem
>Hi Terry,
>You shouldn't be having such a difficult time getting them to align. I've
>done similiar with SRTM/GDEM etc.
>Have you projected the shapefile to wgs84 to review alignment?
>Can you please put together a small subset clip of raster data for area &
>the shapefile you are using. Drop me a the link from Dropbox or other
>service & I will take a look over.
>Cheers,
>Richard
