[Qgis-user] gps tool: greyed buttons
Agustin Lobo alobolistas at gmail.com
Sat Aug 11 08:23:56 PDT 2012
Yes, no problem for connecting to the gps.
Actually, I'm a bit confused because while the track is displayed on the map,
the corresponding layer is not listed in the TOC and cannot be saved.
Also, I've seen that the log file section in the menu
is not greyed before connecting to the gps , so the user can
click and select an output nmea file, but has to do so before
Once you click connected, the log button becomes greyed (perhaps it makes sense:
the file as to be selected before starting to record data, but it
would not hurt having
a simple clarification (i.e.: (to be selected before connecting).
The Add feature and Add track point buttons are always greyed, cannot
find the way
to get them active.
Agus
2012/8/11 Giovanni Manghi <giovanni.manghi at faunalia.pt>:
> On Sat, 2012-08-11 at 13:44 +0200, Agustin Lobo wrote:
>> In the GPS panel, I have always greyed the following buttons:
>> Add feature, Add track point and Log file
>> Are these buttons not yet available or is there a way
>> to make them active?
> is your GPS connected to QGIS and connected to satellites?
> Qgis-user mailing list
