[Qgis-user] Point sampling tool
Javier Bustamante
javier.bustamante.diaz at gmail.com
Sun Aug 12 18:09:44 PDT 2012
Hi, I am new to the list.
I am trying to use the "Point Sampling Tool" plugin to extract some raster
values at specified sampling points.
I have installed the Point Sampling Tool plugin (0.3.3) on Q-gis 1.7.4 under
Kubuntu 11.10 (linux).
We I try to use the tool
I get the following error:
An error has occured while executing Python code:
File
"/home/busta/.qgis/python/plugins/pointsamplingtool/doPointSamplingTool.py",
line 98, in updateFieldsList
self.inData.addItem(str(self.sampItems[i][0].name()) + " : " +
str(self.sampItems[i][j][0]) + " (source point)")
UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in position
3: ordinal not in range(128)
Python version:
2.7.2+ (default, Oct 4 2011, 20:29:37)
[GCC 4.6.1]
QGIS version:
1.7.4-Wroclaw Wroclaw, exported
Python path: ['/usr/share/qgis/python', '/home/busta/.qgis/python',
'/home/busta/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/usr/share/qgis/python/plugins/fTools/tools',
'/media/Iomega_HDD/spartina_modelos/Clasificacion_ahs_casi/shp']
Can someone suggest some possible solution?
Thank you,
Javier
Dr Javier Bustamante
Estación Biológica de Doñana, CSIC
Dept. Wetland Ecology
Américo Vespucio s/n
41092 - Sevilla
Spain
voice: +34 954 466700 ext. 1217
fax: +34 954 621125
e-mail: jbustamante at ebd.csic.es
http://www.ebd.csic.es/bustamante/index.html
-----other links-------
http://last-ebd.blogspot.com/
http://euroconbio.blogspot.com/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120813/79a3d8f9/attachment.html>
