[Qgis-user] Point sampling tool
Salvatore Larosa
lrssvtml at gmail.com
Mon Aug 13 01:30:47 PDT 2012
2012/8/13 Javier Bustamante <javier.bustamante.diaz at gmail.com>
> Hi, I am new to the list.
> I am trying to use the "Point Sampling Tool" plugin to extract some raster
> values at specified sampling points.
> I have installed the Point Sampling Tool plugin (0.3.3) on Q-gis 1.7.4
> under Kubuntu 11.10 (linux).
> We I try to use the tool
> I get the following error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/home/busta/.qgis/python/plugins/pointsamplingtool/doPointSamplingTool.py",
> line 98, in updateFieldsList
> self.inData.addItem(str(self.sampItems[i][0].name()) + " : " +
> str(self.sampItems[i][j][0]) + " (source point)")
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in
> position 3: ordinal not in range(128)
> Python version:
> 2.7.2+ (default, Oct 4 2011, 20:29:37)
> [GCC 4.6.1]
> QGIS version:
> 1.7.4-Wroclaw Wroclaw, exported
> Python path: ['/usr/share/qgis/python', '/home/busta/.qgis/python',
> '/home/busta/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/share/qgis/python/plugins/fTools/tools',
> '/media/Iomega_HDD/spartina_modelos/Clasificacion_ahs_casi/shp']
> Can someone suggest some possible solution?
Hi Javier,
try with the attached patch, should solve the issue!
I don't know if exist a bugtracker for pointsampling plugin, if so, it's
the right place to report this bug!
Also, consider upgrading QGIS!!
Cheers,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120813/acdc695d/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120813/acdc695d/attachment.obj>
