[Qgis-user] id column hidden when table is added to QGIS
Julian Bogdani
jbogdani at gmail.com
Mon Aug 13 02:40:58 PDT 2012
Hello all,
I'm having the following issue with QGIS. When adding a table sqlite text table (Layer > Add Vector Table) QGIS hides my primary key field (having name `id`). I understand also QGIS uses this field as unique id, but I need to have it in the attribute view because all my links and joins use this field.
I'm not able actually to perform a join with my vector tables.
I can neither change the column names, nor create views.
Any suggestion?
Julian Bogdani
http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120813/45c9dd82/attachment.html>
