[Qgis-user] 1 band raster colormap
benoit-3 at bc-consult.com benoit-3 at bc-consult.com
Tue Aug 14 23:14:55 PDT 2012
On 15.08.2012 08:51, Andre Joost wrote:
> Am 15.08.12 07:22, schrieb Matt Boyd:
>> Hi Group,
>> I'm working with some grid data (imported using the zmap format,
>> effectively 1 band rasters). While the psuedocolor and freakout
>> options are okay, they don't provide the level of control I would
>> like
>> over the colormap and using the colormap option with more than a
>> dozen
>> or so colours is somewhat time consuming.
>> Does anyone know of an easy/quick way to create colormaps in/for
>> QGIS?
> You know the plugin for that?
> http://www.bc-consult.com/free/bcccoltbl1.html
> You have to enable experimental plugins and add the repository
> http://www.bc-consult.com/free/plugins.xml
> manually.
Please be aware that the plugin does not work with 'QGIS Dev' (1.9.x).
It is fine to use up to QGIS 1.8 (current stable version) and will be
superseded by Etienne's work from QGIS 1.9.
Thanks,
Benoit
> Greetings,
> André Joost
> Qgis-user mailing list
