[Qgis-user] Do you use the MemoryLayerSaver plugin?
Chris Crook ccrook at linz.govt.nz
Wed Aug 15 00:25:21 PDT 2012
Hi Paolo
Yes, I was thinking of the python bindings - the alternative would be to use the OGR driver, but I couldn't see a way to put more than one layer into a database file (at least not using QgsVectorFileWriter).
Cheers
Chris
________________________________________
Sent: 15 August 2012 17:30
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Do you use the MemoryLayerSaver plugin?
Il 14/08/2012 23:14, Chris Crook ha scritto:
I will upload an experimental version 2.0 of the plugin which implements this to plugins.qgis.org
I have considered another format, which is an SQLite database.  However this creates another set of issues in mapping layers, data types, etc to SQLite formats and back again.  I probably would not use spatialite, as this would add another dependency on the Memory Layer
do you mean the spatialite python bindings?
all the best.
Paolo Cavallini - Faunalia
www.faunalia.eu<http://www.faunalia.eu>
Full contact details at www.faunalia.eu/pc<http://www.faunalia.eu/pc>
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
