[Qgis-user] Transparency for vector layer
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Aug 15 07:45:48 PDT 2012
Hi Both,
Thanks for the responses, that clears that up. Good to know there's already
a feature request for it, save me having to create a new one. ;-)
Jonathan
On 15 August 2012 14:54, richard burcher <drownedfrog at gmail.com> wrote:
> Hi Jonathan,
> There is no global (from what i see) setting for transparency to be applied
> to each category.
> I've tried the following: (win 7 qgis 1.8)
> 1) categorize a polygon layer by some unique id -- classifiy
> 2) right click each symbol color for context menu
> Context menu provides option for transparency for that symbol.
> Cheers,
> Richard
> http://osgeo-org.1560.n6.nabble.com/Transparency-for-vector-layer-tp4995386p4995394.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>  _______________________________________________
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120815/d37b932c/attachment.html>
