[Qgis-user] split features
Andreas Neumann
a.neumann at carto.net
Wed Aug 15 08:38:22 PDT 2012
I believe that the QGIS split function requires the crossing, even if
snapping is perfect. You can snap and CROSS at the same time. No
problem.
Did you try it?
Andreas
On Wed, 15 Aug 2012 06:56:44 -0700 (PDT), skampus wrote:
> this thread comes properly.
> as you said, in order to split a features you have to CROSS the
> element.
> if you have a polygon to be splitted at vertices, i don't understand
> why you
> have to cross it. if you set properly snapping, it's simple to draw
> splitting segment that snap perfectly to vertices of polygon.
> what do you think?
> http://osgeo-org.1560.n6.nabble.com/split-features-tp4995360p4995395.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
