[Qgis-user] SVG Fill
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Aug 16 08:41:09 PDT 2012
Hi Andrew,
Thanks for this. I contacted our own OS Technical Guy (Ilhan) earlier today
however he's on holiday for a couple of weeks apparently.
Jonathan
On 16 August 2012 16:28, Andrew Miller <A.J.Miller at bcs.org.uk> wrote:
> We have been in contact with OS who are in the process of releasing their
> symbology in SLD format (with corresponding SVGs), which can be loaded by
> the latest release of QGIS.  I will find out if we are able to send these
> files to you.
> Andrew
>  On 16 August 2012 13:43, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
>>  Hi List,
>> I'm trying to symbolise Ordnance Survey MasterMap. The OS are nice enough
>> to provide a single SVG file (here:
>> https://www.ordnancesurvey.co.uk/xml/resource/OSMasterMapStyles.svg)
>> with most/all of their symbology in.
>> My question is simple: How do I use these symbols in QGIS?
>> I've found "SVG fill", which is the one I'm trying to use (i.e., with
>> "nonconiferousTreesAndConiferousTreesPattern") and while it does allow me
>> to specify the SVG file, that seems to be all I can do. QGIS seems to
>> assume that the entire contents of the file should be used for styling,
>> while the file has multiple stylings in.
>> I'm guessing mutliple geometries in a single file is valid SVG (it passes
>> the WGC validator), so is this something QGIS can handle, or will I need to
>> source split files?
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/149c84dc/attachment.html>
