[Qgis-user] Different font styles for different label classes
Andreas Neumann a.neumann at carto.net
Thu Aug 16 12:01:18 PDT 2012
Hi Jonathan,
The rule based labeling, as Giovanni said, is not yet available.
If your data is in Postgis you could use a view and introduce a new
column called font-color and use the data-defined font-color settings.
That's probably the best you can do currently.
If you don't use Postgis, you could still introduce the new column and
use the field calculator to set the colors. But this would require
manual updates of the columns whenever the attributes change.
Andreas
Am 16.08.2012 19:31, schrieb Jonathan Moules:
> Hi List,
> I have a single layer I'd like to label in such a way that different
> attributes will get different font styles. For example, a water based label
> would have the Style attribute "waterText", and would be styled as blue
> italics. Another label might have a Style attribute of "heritigateText" and
> be in bold black. (For reference: ArcGIS calls these "classes")
> I've looked at both of the labelling engines that come as default with QGIS
> but can't see any obvious way to do this in either.
> The closest I can find is copying the dataset as many new layers and using
> the "subset" query builder for each layer before then labelling the entire
> layer. But that's obviouslly quite cludgy.
> Can QGIS do this?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
