[Qgis-user] Open Data via Open Standards using Open Source: a new tool from NIWA
Nathan Woodrow madmanwoo at gmail.com
Sat Aug 18 06:34:45 PDT 2012
Yep.  It really should be stored in the same path as when you set
--configpath but there is a bug so you just have to add the
customization.ini file.
- Nathan
On Sat, Aug 18, 2012 at 11:31 PM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> On 08/18/2012 03:22 PM, Nathan Woodrow wrote:
>> We have done something similar with a project at work to build a QGIS
>> based data collection program.  The program is a normal QGIS install
>> that uses the customization feature to remove the interface items, and
>> a plugin to add the extra functionality. http://youtu.be/lBJjZFXgvRA
> Thanks for information.
> So, if I understand customization code correctly, all I need is to add
> 'customization.ini' file to 'resources' directory of my installation ?
> Ivan Mincik
