[Qgis-user] After Qgis installation - GRASS6.4 doesn't start anymore
Etienne Tourigny
etourigny.dev at gmail.com
Thu Aug 23 09:04:51 PDT 2012
You should probably not be installing grass in /usr, this cause
conflicts with packages installed though the package manager.
Why are you building grass anyway? The packaged version should run fine.
I recommend you use the "ubuntugis-unstable" ppa to install qgis,
grass and qgis-grass.
BTW the correct way to uninstall is "sudo apt-get remove qgis" -
autoremove deletes unnecessary packages
Etienne
On Thu, Aug 23, 2012 at 8:16 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> I successfully compiled and installed GRASS6.4 with "make -j2 && sudo
> checkinstall && sudo ldconfig"
> which is usually working perfectly.
> But after installing QGIS I can't start GRASS6.4 itself anymore.
> I try to launch it from the Terminal like:
> x at y:~$ grass64
> Cleaning up temporary files ...
> Starting GRASS ...
> python: can't open file '/usr/lib/grass64/etc/wxpython/gis_set.py':
> [Errno 2] No such file or directory
> Received EXIT message from GUI.
> GRASS is not started. Bye.
> it seems that the QGIS installation somehow overwrites some
> settings/files that are needed for starting
> a pure GRASS session (with GUI).
> I am working on Ubuntu 12.04 and QGIS 1.8 is installed via the
> instructions from qgis.org:
> following lines were added to /etc/apt/sources.list:
> deb http://qgis.org/debian precise main
> deb-src http://qgis.org/debian precise main
> the installation itself was done with:
> sudo apt-get update
> sudo apt-get install qgis
> After uninstalling qgis with "sudo apt-get autoremove qgis" grass64
> can be started again without
> any problems.
> Maybe this is a known issue, but are there any solutions?
> /johannes
> Qgis-user mailing list
