[Qgis-user] [GRASS-user] After Qgis installation - GRASS6.4 doesn't start anymore
Werner Macho
werner.macho at gmail.com
Fri Aug 24 01:51:09 PDT 2012
Hi!
Just as a suggestion ..
If you are self compiling GRASS - you should probably also self
compile QGIS .. As it seems that QGIS expects some GRASS files in
decent positions you could tell QGIS where to find the GRASS version
you would like to use and compile it ..
Maybe that solves a lot of that problems..
And I hope you don't expect QGIS to work with several versions of
GRASS at the same time (out of the box) - that would not work without
some starting scripts where you set PATHS ..
HTH
kind regards
Werner
On Fri, Aug 24, 2012 at 10:45 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
>> Please check how many files remained in /usr/lib/grass64/.
>> Perhaps QGIS removed it to install again GRASS (which failed)?
> Before installing QGIS (at the time when GRASS is still launching), there is no
> grass64 folder in /usr/lib but there is the folder
> /usr/local/grass6.4.3SVN. This seems
> the location where the command grass64 is probably pointing to.
> I am not sure what is the "correct" directory for a selfcompiled GRASS
> installation
> using checkinstall? And I need to build GRASS myself (different
> versions, add ons,
> own scripts and add-ons etc.) and the GRASS compilation itself is not
> the problem.
> After installing QGIS (even from the "ubuntugis-unstable" ppa) the
> usr/lib/grass64 is
> existing. So the QGIS installation (even without the GRASS plugin)
> installs a version
> of GRASS64 and this installation seems to change the link of grass64
> to the new installation.
> So probably just the link for grass64 has to be reset again to my
> "real" GRASS6.4?!
> I tried to reinstall GRASS GIS after the QGIS installation using
> "make -j2 && sudo checkinstall && sudo ldconfig" but the problem still
> remains, although
> I thought that the ldconfig might solve the problem.
> /Johannes
>> What if you reinstall again GRASS6.4 with your
>> guessing,
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
