[Qgis-user] question on the calculation of the distance between points
Sergio Vignali vignalisergio30 at gmail.com
Mon Aug 27 06:13:32 PDT 2012
Thanks Andre,
I've just converted my shp in Monte Mario (3003) and now the distance is in
metres.
2012/8/27 Andre Joost <andre+joost at nurfuerspam.de>
> Am 27.08.12 13:59, schrieb Sergio Vignali:
>  I found the problem. I worked with a postgis vector and I obtained a
>> illegible csv file.
>> Now I have saved the postgis vector as a shp and the distance matrix works
>> well.
>> I have another question, the csv file return a distance as degree (true?),
>> but if I want a linear distance (m), how can I do?
> What Coordinate reference System has your project/your shp?
> If you have lat/lon, you will get results in degrees. If you take a
> projected CRS, you get metres (or feet).
> Greetings,
> Andre Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
Sergio Vignali
CERM Centro Rapaci Minacciati
(Endangered Raptors Centre)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120827/ef251c49/attachment.html>
