[Qgis-user] Fwd: wktraster with Postgis 2.0 in QGIS 1.9 on Linux Mint Maya
Mauricio de Paulo mauricio.dev at gmail.com
Tue Aug 28 12:01:19 PDT 2012
Hi Brian,
I downloaded the sample data and imported to my database and it seems to
work pretty well. I'm using QGIS 1.8, postgis 2.0, postgres 9.1.5, gdal
1.9.1 on ubuntu 12.04.
Sorry for my ignorance but what GDAL version is being released with
linux mint? I couldn't find anywhere online.
The plugin heavily relies on GDAL to perform the visualization so you
need the latest GDAL available to get a decent performance.
 From my first tests I can say that GDAL 1.9.1 has greatly improved
performance and the next versions should improve even further. The
fastest visualization that I have achieved with version 1.9.1 is with
single tiled raster files. Unfortunately I wasn't able to get GDAL to
use overviews so far, but Jorge (GDAL's postgis raster developper) is
researching on this subject.
GDAL versions bellow 1.9 should not be able to read postgis 2.0.
Unfortunately, since postgis 2.0 release, the python loader was
discontinued in postgis source. Recently I have started to make the
necessary changes starting from the old code to get it to work. I don't
know if this is going to be a good solution but it seems possible. I'm
trying to avoid the platform-dependent compilation that postgis' raster
loader has in version 2.0 now that it's being entirely written in C. In
the future I should probably release a simple uploader with the plugin,
without all those options until I'm certain that everything is working
according to the standard.
I'm copying this mail to the list to allow other users to find this
thread later.
Mauricio C. M. de Paulo
Engenheiro Cartógrafo
Mestrando em Sensoriamento Remoto (INPE)
On 08/28/2012 03:56 PM, Brian Fitzgerald wrote:
> PS - Im also unable to "load" raster data into PostGIS using the
> plugin... the icon is greyed out for some reason.
> - Brian
> On Tue, Aug 28, 2012 at 2:20 PM, Brian Fitzgerald <bkfitz at gmail.com
> <mailto:bkfitz at gmail.com>> wrote:
>     Sure.
>     I'm running Ubuntu Mint 13 Cinnamon with Postgres 1.9.5, Postgis
>     2.0. and QGIS 1.9.0
>     I followed this install tutorial:
>     http://linfiniti.com/2012/05/installing-postgis-2-0-on-ubuntu/
>     I loaded the sample vector shapefile into my new 'training'
>     database and opened it in QGIS with no problem.
>     I loaded the sample raster data using the command in the tutorial,
>     it loaded with no problems.  I ran the test query in the tutorial,
>     no problem.  I went into QGIS to load the raster and got an error
>     that referred to some missing python dependencies (i think it was
>     the python-psycopg libs)... so I went to Synaptic and loaded the
>     following:
>     Installed the following packages:
>     libjs-sphinxdoc (1.1.3+dfsg-2ubuntu2.1)
>     libjs-underscore (1.1.6-1ubuntu2)
>     python-dbg (2.7.3-0ubuntu2)
>     python-psycopg2 (2.4.5-1)
>     python-psycopg2-dbg (2.4.5-1)
>     python-psycopg2-doc (2.4.5-1)
>     python2.7-dbg (2.7.3-0ubuntu3.1)
>     python3 (3.2.3-0ubuntu1)
>     python3-dbg (3.2.3-0ubuntu1)
>     python3-minimal (3.2.3-0ubuntu1)
>     python3-psycopg2 (2.4.5-1)
>     python3-psycopg2-dbg (2.4.5-1)
>     python3.2 (3.2.3-0ubuntu3)
>     python3.2-dbg (3.2.3-0ubuntu3)
>     python3.2-minimal (3.2.3-0ubuntu3)
>     I then came back to QGIS to open the raster and no longer get the
>     python error... this time it brings up the "Load PostGIS Raster
>     Layer" just fine and displays my sample raster.  I click on the
>     raster name in the table and it puts it down in the "Table Name"
>     input box.  I then click on OK and get a window that pops up
>     saying "Could Not Load Layer".  I click ok to this and another
>     window comes up that says:  "Could not load PG: dbname=training
>     host=localhost user=postgres password=xxxxxx port=5432
>     schema=public table=srtm_4326 mode=2".  When I click ok to this,
>     the window diappears and nothing happens.
>     I also tried one of our ortho geotiffs using the following command
>     and get the same results:
>     postgres at minty /home/rcgeoadmin/Temp $ raster2pgsql -s 4326
>     /home/rcgeoadmin/Temp/979903.tif | psql training
>     Processing 1/1: /home/rcgeoadmin/Temp/979903.tif
>     Warning 1: TIFFReadDirectory:Unknown field with tag 33919 (0x847f)
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     encountered
>     BEGIN
>     NOTICE:  CREATE TABLE will create implicit sequence
>     "979903_rid_seq" for serial column "979903.rid"
>     NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
>     "979903_pkey" for table "979903"
>     CREATE TABLE
>     INSERT 0 1
>     COMMIT
>     - Brian
>     On Tue, Aug 28, 2012 at 8:24 AM, Mauricio de Paulo
>     <mauricio.dev at gmail.com <mailto:mauricio.dev at gmail.com>> wrote:
>         Hi, Brian.
>         Could you please elaborate a little more about what were you
>         trying to do and what raster configuration you were using? Is
>         it tiled or untiled? One single raster file in the table? Did
>         you build overviews?
>         All the best,
>         On 08/27/2012 07:00 PM, Brian Fitzgerald wrote:
>>         ---------- Forwarded message ----------
>>         From: "Brian Fitzgerald" <bkfitz at gmail.com
>>         Date: Aug 27, 2012 4:57 PM
>>         Subject: wktraster with Postgis 2.0 in QGIS 1.9 on Linux Mint
>>         Maya
>>         To: <wonder.sk at gmail.com <mailto:wonder.sk at gmail.com>>
>>         I'm having problems loading a Postgis 2.0 raster layer into
>>         QGIS 1.9 using your wktraster extension.
>>         The menu comes up, but I get a "could not load layer"
>>         Then a window that says:
>>         "Could not load PG: dbname=training host=localhost
>>         user=postgres password=topology4 port=5432 table= mode=2"
>>         Any ideas?
>>         Brian Fitzgerald, PMP, GISP
>>         bkfitz at gmail.com <mailto:bkfitz at gmail.com>
>>         803.426.3469 <tel:803.426.3469>
> 803.426.3469
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120828/c0886997/attachment.html>
