[Qgis-user] gdal merge raster
skampus stefano.campus at regione.piemonte.it
Tue Aug 28 20:05:33 PDT 2012
when i try to launch the merge command of gdal, it returns this error
File "C:\OSGeo4W\bin\gdal_merge.py", line 36, in
import gdal
File "C:\OSGeo4W\apps\Python27\lib\site-packages\gdal.py", line 2, in
from osgeo.gdal import deprecation_warn
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py", line
21, in
_gdal = swig_import_helper()
17, in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: Impossibile trovare la procedura specificata.
error occurs both in qgis 1.8 and master
same error if i launch the commando from osgeo prompt:
C:\>gdal_merge.bat -of GTiff -o E:/temp/RiesgoGuaya/Danno_10cm.tif
E:/temp/Riesg
oGuaya/Danno_A_10cm.tif E:/temp/RiesgoGuaya/Danno_B_10cm.tif
E:/temp/RiesgoGuaya
/Danno_C_10cm.tif
C:\OSGeo4W\\apps\Python27\lib\site.py:158: Warning: 'with' will become a
reserve
d keyword in Python 2.6
'import site' failed; use -v for traceback
C:\OSGeo4W\\apps\Python27\lib\linecache.py:127: Warning: 'with' will become
a re
served keyword in Python 2.6
  File "C:\OSGeo4W\\bin\gdal_merge.py", line 36, in <module>
    import gdal
ImportError: No module named gdal
any idea? thank you in advance
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-merge-raster-tp4998458.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
