[Qgis-user] QGIS & Proxy auto configuration
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Aug 31 04:36:56 PDT 2012
Hi list,
I have a feature suggestion I'll put here before logging a ticket.
Currently QGIS requires manual configuration of proxy settings, however
there's a semi-standard called "Web Proxy Autodiscovery Protocol" (
https://en.wikipedia.org/wiki/Web_Proxy_Autodiscovery_Protocol ) which some
organisations (my own included) use to make their proxy setup more easily
transferable between machines and software applications. It also allows for
redundency (you can point at multiple proxy servers in the same file).
There's a bit more info about Proxy auto-config here:
https://en.wikipedia.org/wiki/Proxy_auto-config
Would this be worth putting into QGIS? We would benefit from it, but does
anyone else's organisation use this? Anyone know anything about it?
There are already Open Source implementations out there (i.e. Firefox), so
its probably possible to nab a library from somewhere to easy
implementation.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120831/778ab267/attachment.html>
