[Qgis-user] No qgis-dev via OSGeo4W today
Anita Graser
anitagraser at gmx.at
Mon Dec 3 09:36:35 PST 2012
On Mon, Dec 3, 2012 at 4:49 PM, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> Am 03.12.2012 15:08, schrieb Anita Graser:
>> Hi,
>> Just tried to install both qgis and qgis-dev on a new machine using
>> OSGeo4W. qgis installed fine but qgis-dev didn't ... there is no
>> shortcut on desktop an no qgis.exe in the bin folder.
>> Can anyone confirm?
> I dont't want to spoil my running version ;-)
> Have you got a setup.log or setup.log.full in C:\OSGEO4W\var\log?
> It might tell you where the installer breaks.
Hi Andre,
This is setup.log
2012/12/03 18:30:40 Downloaded
C:\Users\agraser\Desktop/http%3a%2f%2fdownload.osgeo.org%2fosgeo4w/./release/qgis/qgis-dev/qgis-dev-1.9.0-129.tar.bz2
2012/12/03 18:30:42 Running preremove script for qgis-dev
2012/12/03 18:30:42 running: cmd.exe /c C:\OSGeo4W\etc\preremove\qgis-dev.bat
2012/12/03 18:30:42 Uninstalling qgis-dev
2012/12/03 18:30:46 Extracting from
file://C:\Users\agraser\Desktop/http%3a%2f%2fdownload.osgeo.org%2fosgeo4w/./release/qgis/qgis-dev/qgis-dev-1.9.0-129.tar.bz2
2012/12/03 18:31:27 running: cmd.exe /c C:\OSGeo4W\etc\postinstall\qgis-dev.bat
2012/12/03 18:31:27 abnormal exit: exit code=255
2012/12/03 18:31:48 note: Installation abgeschlossen
2012/12/03 18:31:48 Ending cygwin install
and setup.log.full
Installing file cygfile:///bin/qgis-dev.exe
Installing file cygfile:///bin/qgis-dev-browser.exe
Installing file cygfile:///bin/qgis-dev.bat.tmpl
Installing file cygfile:///bin/qgis-dev-browser.bat.tmpl
Installing file cygfile:///etc/postinstall/qgis-dev.bat
Installing file cygfile:///etc/preremove/qgis-dev.bat
Visited: 65 nodes out of 212 while creating dependency order.
Dependency order of packages: msvcrt shell avce00 openssl curl expat
fcgi fftw freetype-mingw iconv freexl libjpeg zlib libjpeg12 libtiff
libgeotiff proj-hpgn proj-datumgrid proj hdf5 geos libmysql sqlite3
netcdf libpq xerces-c-vc9 hdf4 ogdi xerces-c gdal15dll gdal18dll
spatialite gdal python-core python-wrapper python-help python
python-numpy gdal-python gpsbabel pdcurses libpng msys tcltk
python-win32 wxpython python-pil pyopengl grass gsl-libs
libspatialindex matplotlib qt4-libs osg-libs osgearth-libs psycopg2
pyqt4 pyspatialite sip qscintilla python-qscintilla qwt5-libs-qt4
qgis-common qgis qgis-dev
C:\OSGeo4W>textreplace -std -t bin\qgis-dev.bat
C:\OSGeo4W>textreplace -std -t bin\qgis-dev-browser.bat
"mkdir" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
C:\OSGeo4W>if not ==0 mkdir
"C:\Users\agraser\AppData\Roaming\Microsoft\Windows\Start
Menu\Programs/OSGeo4W"
