[Qgis-user] Problem with qgis-web-client configuration
Salvatore Larosa lrssvtml at gmail.com
Sun Dec 9 07:38:50 PST 2012
2012/12/9 Otto Dassau <dassau at gbd-consult.de>
> Hi Salvatore,
> Am Sun, 9 Dec 2012 16:13:07 +0100
> schrieb Salvatore Larosa <lrssvtml at gmail.com>:
> > Hi Otto,
> > > Hi,
> > > I installed qgis server version 1.8 using ubuntu precise. The WMS and
> WFS
> > > work, if I add them to QGIS. Now I would like to play with the
> > > qgis-web-client. I can see the web-client but the test maps "Hello" and
> > > "Country" are loading and loading ... but are not visible.
> > > I guess I missed something simple to configure. But the log files don't
> > > say anything, except for some missing css files in blueprint.
> > stupid question: Do you have renamed GlobalOptions.js into site/js
> folder ?
> > Also, check /var/log/apache2/error.log to more info about the issue.
> > Regards,
> > -SL
> yes, for the HelloWorld example I renamed GlobalOptions.js.templ-4326
> to GlobalOptions.js and changed var serverAndCGI path to
> "/cgi-bin/qgis_mapserv.fcgi".
Add also the hostname: "http://localhost/cgi-bin/qgis_mapserv.fcgi"
If you want shorter url, I guess you have to add/change the rules in your
virtualhost.
Regards,
-SL
> There is nothing about this issue in /var/log/apache2/error.log.
> Thanks
> Otto
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121209/6f6021ca/attachment.html>
