[Qgis-user] Sextante tool box problems
Victor Olaya volayaf at gmail.com
Tue Dec 11 10:56:52 PST 2012
That message is not the problem with the buffer, it is another
problem. You have a model that includes a SAGA algorithm (it is an
example model), and you probably do not have SAGA installed so it
complains and it writes it to the log.
You problem description  should be in the SEXTANTE log, but in the
info branch, tagged as "GRASS console output". That's where you can
find why your buffer it is not working
Regards
Victor
2012/12/11 Nick Hopton <nhopton at gmail.com>:
> QGIS 1.9 Master nightly build from http://qgis.org/debian-nightly. Ubuntu
> 12.10 Precise (amd64).
> I've been having problems using the Sextante tool box. For example,
> attempting to buffer points in a shapefile using v.buffer.distance fails
> with the message "Could not load model watersheds.model
> ALGORITHM:saga:catchmentarea(parallel)".
> I don't understand this, can anyone help?
> Regards,
> Nick.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-tool-box-problems-tp5022297.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
