[Qgis-user] Sextante tool box problems
Filipe Dias filipesdias at gmail.com
Wed Dec 12 02:36:30 PST 2012
Hi
Please add your notes to this ticket
http://hub.qgis.org/issues/6862
On Wed, Dec 12, 2012 at 10:33 AM, Nick Hopton <nhopton at gmail.com> wrote:
> Victor Olaya-3 wrote
> > If you go to the SEXTANTE configuration dialog, you will see a "GRASS"
> > entry, and there is an option to enable console output logging. Enable
> > it, run your GRASS command again...and hopefully you will have
> > information about what is happening
> Here is the console output log for grass:v.parallel:
> GRASS execution console output
> Cleaning up temporary files ...
> Starting GRASS ...
> GRASS_INFO_ERROR(4801,1): MAPSET user not found
> GRASS_INFO_END(4801,1)
> /home/nick/.qgis//sextante/tempdata/grassdata/temp_location/user: Not a
> valid GRASS location
> Starting GRASS ...
> GRASS_INFO_ERROR(4837,1): MAPSET user not found
> GRASS_INFO_END(4837,1)
> A few days ago I had the problem described here:
> http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-python-error-td5020446.html
> and fixed it as suggested (by changing the first line of file __init__.py).
> Whether this has anything to do with the problem I don't know.
> Nick.
> http://osgeo-org.1560.n6.nabble.com/Sextante-tool-box-problems-tp5022297p5022430.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121212/7875a2f9/attachment.html>
