[Qgis-user] Qgis server getPrint problems
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sat Dec 15 02:19:58 PST 2012
Hi Mirko
For svg fill, line pattern fill and point fill, Qt needs an x-server for
printing to pdf (therefore the crash).
Two workarounds are possible:
- Print composition as raster (in that case, the whole content is
printed to a QImage first)
- Run an x-server on the server machine.
Regards,
Marco
On 15.12.2012 10:21, mirko wrote:
> I have some issues printing my map using getPrint service. If i use a simple
> symbol it works fine, but if i use composed symbol i get "Internal server
> error" after doing print request.
> Correct code of symbols:
> <renderer-v2 symbollevels="0" type="RuleRenderer">
> <rules>
> <rule filter=" "layer" = 'EDIFICIO'"
> symbol="0"/>
> <rule filter=" "layer" = 'Ed_segnal_b'"
> symbol="1"/>
> <rule filter=" "layer" = 'Ed_segnal_a'"
> symbol="2"/>
> </rules>
> <symbols>
> <symbol outputUnit="MM" alpha="1" type="fill" name="0">
> <layer pass="0" class="SimpleFill" locked="0">
> <prop k="color" v="30,68,196,255"/>
> <prop k="color_border" v="0,0,0,255"/>
> <prop k="offset" v="0,0"/>
> <prop k="style" v="solid"/>
> <prop k="style_border" v="solid"/>
> <prop k="width_border" v="0.26"/>
> </layer>
> </symbol>
> <symbol outputUnit="MM" alpha="1" type="fill" name="1">
> <prop k="color" v="205,70,97,255"/>
> </layer>
> </symbol>
> <symbol outputUnit="MM" alpha="1" type="fill" name="2">
> <prop k="color" v="225,192,0,255"/>
> </layer>
> </symbol>
> </symbols>
> </renderer-v2>
> With following code instead it doesn't work:
> <rules>
> <rule filter="Layer = 'Ed_segnal_a'" symbol="1"/>
> <rule filter="Layer = 'Ed_segnal_b'" symbol="2"/>
> <rule description="EDIFICIO" filter="Layer = 'EDIFICIO'"
> symbol="3" label="EDIFICIO"/>
> </rules>
> <symbols>
> <symbol outputUnit="MapUnit" alpha="1" type="fill"
> name="1">
> <layer pass="0" class="LinePatternFill" locked="0">
> <prop k="color" v="0,0,0,255"/>
> <prop k="distance" v="8.5"/>
> <prop k="lineangle" v="0"/>
> <prop k="linewidth" v="0.3"/>
> <prop k="offset" v="5"/>
> </layer>
> <prop k="offset" v="0"/>
> </layer>
> <layer pass="0" class="SimpleLine" locked="0">
> <prop k="capstyle" v="flat"/>
> <prop k="customdash" v="0"/>
> <prop k="joinstyle" v="round"/>
> <prop k="penstyle" v="solid"/>
> <prop k="use_custom_dash" v="0"/>
> <prop k="width" v="0.4"/>
> </layer>
> </symbol>
> name="2">
> <prop k="lineangle" v="90"/>
> </layer>
> </layer>
> </layer>
> </symbol>
> name="3">
> <prop k="color" v="104,104,104,255"/>
> <prop k="distance" v="2"/>
> <prop k="lineangle" v="45"/>
> <prop k="linewidth" v="0.5"/>
> </layer>
> </symbol>
> <symbol outputUnit="MM" alpha="1" type="line"
> name="@0 at 0">
> <prop k="capstyle" v="square"/>
> <prop k="customdash" v="5;2"/>
> <prop k="joinstyle" v="bevel"/>
> <prop k="width" v="0.26"/>
> </layer>
> </symbol>
> name="@0 at 1">
> </layer>
> </symbol>
> name="@0 at 2">
> </layer>
> </symbol>
> name="@1 at 0">
> </layer>
> </symbol>
> name="@1 at 1">
> </layer>
> </symbol>
> name="@2 at 0">
> </layer>
> </symbol>
> name="@2 at 1">
> </layer>
> </symbol>
> name="@3 at 0">
> </layer>
> </symbol>
> </symbols>
> </renderer-v2>
> I have tried with the same last symbols coverted into svg but without
> sccess. It seems it can not render the symbols for printing.
> Some ideas
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Qgis-server-getPrint-problems-tp5023188.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
