[Qgis-user] Master install Problems
Nick Hopton
nhopton at gmail.com
Sat Dec 22 04:02:10 PST 2012
Ubuntu 12.10 (amd64), repository is qgis.org/debian-nightly precise main.
I'm trying to install the nightly build of Master on my system but have a
hit a problem, see below. Searching on the Internet suggests that other
people have experienced similar problems, but with no solution mentioned.
Can anyone help me with this?
nick at nick-6150M2MA:~$ sudo apt-get install qgis
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
qgis : Depends: qgis-providers (= 1.9.0+git20121208+7841975~precise1) but
it is not going to be installed
Depends: qgis-common (= 1.9.0+git20121208+7841975~precise1) but it
Recommends: qgis-plugin-globe but it is not going to be installed
Recommends: qgis-plugin-grass but it is not going to be installed
Recommends: python-qgis but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Regards,
Nick.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Master-install-Problems-tp5024405.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
