[Qgis-user] WFS and QGIS - no sign of the data
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Dec 28 03:16:15 PST 2012
Upon further investigation it seems QGIS doesn't support WFS 1.1.0 but lets
you add it anyway (it just doesn't work). I've therefore reported this as a
bug.
No idea why only some layers loaded with WFS 1.0.0; works fine today.
Jonathan
On 27 December 2012 17:30, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> I have a WFS layer being served by GeoServer. When I add it to QGIS 1.8.0,
> after a long delay, QGIS adds it to the layer menu.
> Except there's absolutely no data on the map.
> The map itself is zoomed to 1:11. I'm at about 0,0.
> The data is in British National Grid (27700) and comprises about 50,000
> polygons. I specified the CRS at adding time and the data is stored in the
> database in 27700.
> QGIS has picked up the attribute table structure but that's it. I can't
> "zoom to extent", and there's nothing in the attribute table. Searching the
> attribute table finds nothing either.
> I can't see any QGIS errors. The WFS GetCapabilities looks like this:
> <wfs:WFS_Capabilities version="1.1.0" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xmlns="
> http://www.opengis.net/wfs" xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ows="http://www.opengis.net/ows" xmlns:gml="
> http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="
> http://wppgeog3:8082/geoserver/schemas/wfs/1.1.0/wfs.xsd" xmlns:Test="
> www.warwickshire.gov.uk/test" updateSequence="222">
> <ows:ServiceIdentification>
> <ows:Title>
> GeoServer Web Feature Service
> </ows:Title>
> <ows:Abstract>
> This is the reference implementation of WFS 1.0.0 and WFS 1.1.0, supports
> all WFS operations including Transaction.
> </ows:Abstract>
> <ows:Keywords>
> <ows:Keyword>
> WFS
> </ows:Keyword>
> <ows:Keyword>
> WMS
> </ows:Keyword>
> <ows:Keyword>
> GEOSERVER
> </ows:Keyword>
> </ows:Keywords>
> <ows:ServiceType>
> WFS
> </ows:ServiceType>
> <ows:ServiceTypeVersion>
> 1.1.0
> </ows:ServiceTypeVersion>
> <ows:Fees>
> NONE
> </ows:Fees>
> <ows:AccessConstraints>
> NONE
> </ows:AccessConstraints>
> </ows:ServiceIdentification>
> <ows:ServiceProvider>
> <ows:ProviderName>
> God
> </ows:ProviderName>
> <ows:ServiceContact>
> <ows:IndividualName>
> GIS
> </ows:IndividualName>
> <ows:PositionName>
> GIS
> </ows:PositionName>
> <ows:ContactInfo>
> <ows:Phone>
> <ows:Voice/>
> <ows:Facsimile/>
> </ows:Phone>
> <ows:Address>
> <ows:City>
> GIS
> </ows:City>
> <ows:AdministrativeArea/>
> <ows:PostalCode/>
> <ows:Country>
> UK
> </ows:Country>
> </ows:Address>
> </ows:ContactInfo>
> </ows:ServiceContact>
> </ows:ServiceProvider>
> <ows:OperationsMetadata>
> <ows:Operation name="GetCapabilities">
> <ows:DCP>
> <ows:HTTP>
> <ows:Get xlink:href="http://wppgeog3:8082/geoserver/wfs"/>
> <ows:Post xlink:href="http://wppgeog3:8082/geoserver/wfs"/>
> </ows:HTTP>
> </ows:DCP>
> <ows:Parameter name="AcceptVersions">
> <ows:Value>
> 1.0.0
> </ows:Value>
> <ows:Value>
>  1.1.0
> </ows:Value>
> </ows:Parameter>
> <ows:Parameter name="AcceptFormats">
> <ows:Value>
> text/xml
> </ows:Value>
> </ows:Parameter>
> </ows:Operation>
> <ows:Operation name="DescribeFeatureType">
> <ows:DCP>
> <ows:HTTP>
> </ows:HTTP>
> </ows:DCP>
> <ows:Parameter name="outputFormat">
> <ows:Value>
> text/xml; subtype=gml/3.1.1
> </ows:Value>
> </ows:Parameter>
> </ows:Operation>
> <ows:Operation name="GetFeature">
> <ows:DCP>
> <ows:HTTP>
> </ows:HTTP>
> </ows:DCP>
> <ows:Parameter name="resultType">
> <ows:Value>
> results
> </ows:Value>
> <ows:Value>
> hits
> </ows:Value>
> </ows:Parameter>
> <ows:Value>
> </ows:Value>
> <ows:Value>
> GML2
> </ows:Value>
> <ows:Value>
> GML2-GZIP
> </ows:Value>
> <ows:Value>
> SHAPE-ZIP
> </ows:Value>
> <ows:Value>
> application/gml+xml; version=3.2
> </ows:Value>
> <ows:Value>
> csv
> </ows:Value>
> <ows:Value>
> gml3
> </ows:Value>
> <ows:Value>
> gml32
> </ows:Value>
> <ows:Value>
> json
> </ows:Value>
> <ows:Value>
> text/xml; subtype=gml/2.1.2
> </ows:Value>
> <ows:Value>
> text/xml; subtype=gml/3.2
> </ows:Value>
> </ows:Parameter>
> <ows:Constraint name="LocalTraverseXLinkScope">
> <ows:Value>
> 2
> </ows:Value>
> </ows:Constraint>
> </ows:Operation>
> <ows:Operation name="GetGmlObject">
> <ows:DCP>
> <ows:HTTP>
> </ows:HTTP>
> </ows:DCP>
> </ows:Operation>
> </ows:OperationsMetadata>
> <FeatureTypeList>
> <Operations>
> <Operation>
> Query
> </Operation>
> </Operations>
> <FeatureType xmlns:Test="www.warwickshire.gov.uk/test">
> <Name>
> Test:OS_MM2_CONWY_TOPOGRAPHIC_AREA
> </Name>
> <Title>
> </Title>
> <Abstract/>
> <ows:Keywords>
> <ows:Keyword>
> </ows:Keyword>
> <ows:Keyword>
> features
> </ows:Keyword>
> </ows:Keywords>
> <DefaultSRS>
> urn:x-ogc:def:crs:EPSG:27700
> </DefaultSRS>
> <ows:WGS84BoundingBox>
> <ows:LowerCorner>
> -4.02931861385795 52.31146421508856
> </ows:LowerCorner>
> <ows:UpperCorner>
> -3.6884903044783406 53.34934458176171
> </ows:UpperCorner>
> </ows:WGS84BoundingBox>
> </FeatureType>
> </FeatureTypeList>
> ...filter capabilties removed.
> </wfs:WFS_Capabilities>
> BUT: It only doesn't work if its WFS 1.1.0.
> It kind of works in 1.0.0, but many features are missing (the attribute
> table claims 1438 features when there are ~50,000).
> WFS 1.0.0 works fine in MapInfo.
> Any thoughts? Is this a QGIS issue or a GeoServer issue? Have I set
> something up wrong? Do I need to be reporting this to someone as a bug?
> Cheers,
> Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121228/97955211/attachment.html>
