[Qgis-user] postgis / PHP
Andreas Neumann a.neumann at carto.net
Thu Feb 9 08:21:15 PST 2012
 You can use the Postgis commands "ST_AsText()" and "ST_GeomFromText()"
 for this purpose. If you want to extract x/y you can use
 ST_AsText(ST_X(the_geom)) AS x.
 Hope this helps? It is really easy - not complicated at all.
 Andreas
 On Thu, 9 Feb 2012 16:04:29 -0000, uk52rob wrote:
> Does anyone know of a simple PHP script which can be used to connect
> to a postgis DB and load / update a point layer?
> I really need something that would decode the 'the_geom' field to X/Y
> values, then re-encode on update.
> Thanks
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
